on the back of the fat frog theres an 8 pin locking socket for a remote
now i was wondering if you can use the zero88 level 6 controller as a remote?
sort of remote fader triggers or something along thoes lines
any idears ?
or should i just flog the level 6 controller
Elliott Silk & Sam Raby
Exstage Theatre Services
www.exstagetheatreservices.co.uk
The remote switches socket works on contact closures between each input and ground. So an Analogue Level 6 *might* cause the remote switches to be read as closed when the faders are lowered, however it also needs to cause the remote switches to be read as open when the faders are raised.
Try it and see, you won't do any harm to either the Level 6 or the Fat Frog. Let us know how you get on.
