Hi there,
bit of a newbie to using the Fat Frog desk, but i need help ready for august :)
The theatre which i will be doing the lighting has 8 moving heads (4 Mac 250+ , 4 Robe Spot 250CT)
How would i be able to eg: Program a search like scene on the stage? but for step 1, make the lighting move into their positions by pressing the GO button.
Sorry but i have no experience on these desks
Alex :)
hey there alex
once you have the movers running on the desk and have controll of them , the best thing i can sujjest is that you select the fixtures you want to use for the search light scene , then leave them open white , no gobo or colour , then press the position button or the wheel group button till you see
Effect Size X Size Y
that will allow you to make shapes with the beams e.g. figure of 8 triangle circle
set the sizes to what ever you wish , then press position or wheel group again and you can set the speed and offset ,so they either do or dont move in sync
save that as a memory then program the postion you want straight after and take of the ltp fade time , and set postion to snap and then save that as the memory after
example
Memory 1 : seachlights , movers making shapes
memory 2 : snap to position
i hope that helps ,
best of luck and hope i can help you more :)
fellow frog newbie
Sam :)
one other thing alex ,
had a flick through the forums
you might find this usefull
http://www.aux99.co.uk/blue-room/Copy%20of...gram%20V2.5.ppt
its a training presentation on the fat frog ,
aka a get you started guide
hope it helps
Elliott Silk & Sam Raby
Exstage Theatre Services
www.exstagetheatreservices.co.uk
