Programming on ORB
Jimbob
Hi all I have a few questions about programming the ORB
1. How do you program conventional lights to do a chase in a cue stack ?
If I program a Cue stack and want the next cue to be a chase is this possible ?
As far as I understand you have to convert another Cue stack to a chase. This would mean going between 2 Cue stacks one for normal Cues and
one Cue stack for the chase is this right ?
2. How do you program moving Heads to Pan about the stage in a cue is it the same as above ?
Thanks James
James,
You don't need to use another cue stack to be part of a chase. You can use the in built chase options. {Shift} {Effect} key press will take you to the in built effects part of the desk. Select the channels that you want to be part of the effect and then select what you would like them to do. There are loads of different of colours pans and other effects. If you have also the auto groups and and auto palettes on (from the patch screen) then it will make things obviously easier to select stuff for the chases.
If you then save the cue that you want with the effect running - it's loaded as part of the cue next time.
Ben
