I have programmed a chase into a submaster. When I go to run mode and activate the sub, it only outputs the first step. If I turn the chase speed down to click off, the up again, the chase starts up. Is this correct???
Best wishes
Jon
Hi Jon
The speed of the chase is stored along with the chase steps - if you go back into Program mode, select a step and set the speed you require, then when you overwrite the step (by pressing the PROGRAM/GO button and selecting <Overwrite>), the chase will output at the speed you have defined.
I hope this helps,
Peter
  • 1 year later...
