lxkev Posted May 13, 2009 Report Posted May 13, 2009 got the desk 2day! Only one thing i dont get, i load a cue stack into the master playback... Why does the cue stack fader have to be up and the playback fader up at 100%? Cant i just load a cue stack into the master playback, and leave the stack fader down? But good work guys Quote I need a new job
Kirkup_xp Posted May 14, 2009 Report Posted May 14, 2009 Hi Kev Hope you're getting on well with the desk - the two sets of faders (Playbacks and Master Playbacks) are mixed Latest Takes Precidence so the last one you moved will take precidence over the other ones, grabbing the output value. With the cue stack selected, you should be able to move the Master Playback "HTP Master" to 0% and pick up the level then return it to 100%. I hope this helps - let us know how you're getting on with the desk, Kind Regards, Quote Peter Kirkup
