mikewoodld Posted May 5, 2009 Report Share Posted May 5, 2009 Where might one go to get a working library made for the VIVID LED by ETC/Selador? I tried making one... actually several, and can't get them to work for the life of me. the main issues I'm having are that I can't get the color picker to work, even with the "mix" thing selected in the profile. I also want the intensity to default to 100%, but it won't do that - both in the profile and in the edit fixtures on the console. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted May 6, 2009 Report Share Posted May 6, 2009 Hi Mike A profile already exists for the Selador Vivid range - it's under "selador", "x7" in the library. The profile is the same for the Vivid and Paletta fixtures. The colour picker will not work with more than 3 constituant colours at the moment (Red, Green, Blue, or Cyan, Magenta, Yellow). We may expand this in the future. As for the default intensity to 100%, this isn't possible at present - Intensity always defaults to 0% regardless of how you have it set in the profile - this is so that a "Clear" desk with no playbacks active or nothing in the programmer results in a blackout on stage. I hope this helps clear things up - let us know how you get on with the X7s. Kind Regards, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
mikewoodld Posted May 12, 2009 Author Report Share Posted May 12, 2009 Profile doesn't work. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted May 12, 2009 Report Share Posted May 12, 2009 Profile doesn't work. Hi Mike Can you be more specific about what doesn't work with the profile? Thanks, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
mikewoodld Posted June 1, 2009 Author Report Share Posted June 1, 2009 The profile will not control the fixtures. At all. I will try again now that the other problems are fixed with the board. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted June 12, 2009 Report Share Posted June 12, 2009 Hi Mike How did you get on with trying it? As far as I can tell the profile should work. Kind Regards, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
