joefrog Posted May 1, 2009 Report Share Posted May 1, 2009 after a recent upgrade to the latest frog firmware- and adding nine LED RGB lights, it appears my fatfrog does not retain memory after being switched off. I have checked in superuser and it says that the battery is OK. am i turning it off right? as there is not power switch i just turn it off at the plug. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
joefrog Posted May 5, 2009 Author Report Share Posted May 5, 2009 Come on guys!! I need help!!!! Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted May 6, 2009 Report Share Posted May 6, 2009 Hi Joe Sorry for the delay in response - it's probably best to change the battery as a precaution as this is the biggest cause of a problem like this. Even though the software says it is OK, it is possible that the battery is border line and not reporting correctly. The battery can be changed by any Zero 88 dealer or you can send the desk back to us - please contact Keith (krogers@zero88.com) for details. I hope this helps, Kind Regards, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
joefrog Posted May 7, 2009 Author Report Share Posted May 7, 2009 Hi Joe Sorry for the delay in response - it's probably best to change the battery as a precaution as this is the biggest cause of a problem like this. Even though the software says it is OK, it is possible that the battery is border line and not reporting correctly. The battery can be changed by any Zero 88 dealer or you can send the desk back to us - please contact Keith (krogers@zero88.com) for details. I hope this helps, Kind Regards, Peter Im starting to agree. it saves it intermittently. EDIT: I have spoken to keith, he is now out of the office until tuesday. he has given me a PDF explaining how to do maintenance on the desk. Am i right in thinking that the fatfrog uses a CR2032 watch battery? If so, i will pop to the shops tomorrow morning before school and fit it later tomorrow. is is pretty easy? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted May 8, 2009 Report Share Posted May 8, 2009 Yep, you are correct - as long as the Fat Frog is a generation 2 hardware (most are) then it takes a normal CR2032 and it is very easy to fit. I hope this solves the problems you're having Quote Peter Kirkup Link to comment Share on other sites More sharing options...
