Hi,
At the previous show I had the LCD-screen for the fixtures just fall down into the desk ?? Is the LCD-displays just glued up, is this fixable (be sent in or repaird at home), Is this a qulity thing ?
The LCD still works :) but is not readable due that it is inside the desk.
Another thing. Every now and then when I turn on the desk It halt's. And when I take the power off/on again it works fine..
Not a big problem but annoying..
Anyway.. Tank you for a superb fesk and an even more superb service..
cheers
Eivind Naley
Naley Production
The LCD displays are screwed into pillars on the front panel. It sounds like all your screws have fallen out!
I recommend you open up your desk and reattach the LCD to the panel, as if it is rattling around, the connections on the PCB could be shorting out against the metalwork. This could be the cause of your desk crashing.
The screw size on the wheel LCD is M2x6mm if you've lost them all!
