Capture Polar integration
Bilderbuch
i know that i can visualise over ethernet everthing from my Leap Frog with Capture Polar like it is mentioned in the manual.
But is also possible like with Lightconverse to have bidirectional connection so that i can for example position my movings in Capture an the console takes that values?
And so is it also possible that the frog takes the patch from Capture?
Regards
Bilderbuch
Hi Bilderbuch
At the moment the integration with Capture is only for visualisation, not for bidirectional communications. We may look to change this in the future though - your thoughts have been added to our future ideas. As you know, you can achieve this bidirectional communications with LightConverse.
I hope this helps,
Peter
Peter Kirkup
