Bilderbuch Posted April 23, 2009 Report Posted April 23, 2009 Hello, i know that i can visualise over ethernet everthing from my Leap Frog with Capture Polar like it is mentioned in the manual. But is also possible like with Lightconverse to have bidirectional connection so that i can for example position my movings in Capture an the console takes that values? And so is it also possible that the frog takes the patch from Capture? Regards Bilderbuch Quote
Kirkup_xp Posted April 23, 2009 Report Posted April 23, 2009 Hi Bilderbuch At the moment the integration with Capture is only for visualisation, not for bidirectional communications. We may look to change this in the future though - your thoughts have been added to our future ideas. As you know, you can achieve this bidirectional communications with LightConverse. I hope this helps, Peter Quote Peter Kirkup
Bilderbuch Posted April 23, 2009 Author Report Posted April 23, 2009 Hello Peter, thank you i thought as much. So i will purchase a Lightconverse licence. Bilderbuch Quote
