OK, so I'm pretty sure I know the answer, I just need confirmation.
FatFrog, going to setup various states on the faders, then save them to subs.
I then want to use those subs to setup a state, then save that overall state (made up of subs) onto a scene memory.
I assume that just works, right? That the scene memory will record the output of the subs?
Rob
Yes that will work. If you're using Moving Lights and you're in Partial Programming mode, make sure the ReplayTag option (under Program Mode in Desk Setup) is set to Add so that your tag states will be what you expect.
