Hello everyone,
Is it possible to mix effects? So I want the following:
1. submaster with an effect for pan (left to right)
2. submaster with an effect for tilt (up and down).
Now I want to mix them, to create circles or ovals. The problem is when I open effect 1, and then effect 2, effect 1 is stopped again!
Can somebody help me? Maybe there is a possibility for a new feature?
Thanks in forward.
(Sorry for my english, I'm dutch)
Yes you can, from the effects palette window open the effects window and untag the tilt so only pan is assigned! Do the same for the tilt by untagging the pan!
I work usually in the same way and it works perfectly!!
  • 6 months later...
