Bilderbuch Posted March 24, 2009 Report Posted March 24, 2009 Hi, maybe it would be possible to add a shortcut or kind of key combination for a "Palette View". That means all Palettes on the Screen with a simple shortcut. May be Color Palette top right, Beamshape top left, Position bottom right and group bottom left. I know that i can do it with the size function on the special page 1. But i know from chamsys to you press ctrl and a button so the above mentioned windows are well arranged for a quick access no matter what size they had before. Regards Bilderbuch Quote
Kirkup_xp Posted March 24, 2009 Report Posted March 24, 2009 Hi Bilderbuch You can achieve this using Macros on the desk - the way I would do this is to record the macro as follows: MACRO <hold MFK to start recording> SPECIAL Page Up & Down Together (this forces Page 1) CLOSE CLOSE CLOSE... CLOSE (I do this about 10 times, to close any existing open windows) SHIFT+COLOUR SIZE SIZE... SIZE SHIFT+BEAMSHAPE SIZE SIZE... SIZE SHIFT+POSITION SIZE SIZE... SIZE SHIFT+GROUP SIZE SIZE... SIZE MACRO (to stop recording) Then you can attach the macro to a cue or submaster if needed. Quote Peter Kirkup
Bilderbuch Posted March 24, 2009 Author Report Posted March 24, 2009 Thanks Peter, that sounds good. Quote
