robo 812
masonpendrey
Hi Peter
I have come up with a problem on my Leapfrog 48.
I have been using 12 Roboscan 1220 iir/ 4 Mac 500/ 2 Roboscan 812.
When i set them up on the desk, it let me load all the fixture fine.
And I could control them all,
I then started to set up my palettes all worked fine till I did the 812s, I could not get then to replay after recording them to palettes all the others worked fine .
I then tried to record them to submasters and they would not replay there either.
Is it something I am doing or is it a problem.
many thanks Mason :blink:
Hi Mason
This is a feature of the Smart Tags functionality on the desks. With Smart Tags enabled, if the shutter channel is at 0% the desk won't store any information about that fixture (it assumes that Shutter = 0 means the fixture is in blackout). The easiest thing to do is to modify the Default value for Shutter to 1% in Edit Fixtures and then storing the scenes will work as expected.
I hope this helps,
Peter
