NathanY Posted February 20, 2009 Report Posted February 20, 2009 Is there a setting for telling the desk (and colour picking ) that i'm only using RGB fixtures? I've just created some RGB fixtures, with RGB on the wheel goup. When i load them on the desk the wheels become CMY. Any ideas? Nathan Quote
Kirkup_xp Posted February 20, 2009 Report Posted February 20, 2009 Hi Nathan Hold down SETUP and press COLOUR - then choose the Colour Edit Mode - the desk will let you choose between RGB and CMY. I hope this helps, Peter Quote Peter Kirkup
NathanY Posted February 23, 2009 Author Report Posted February 23, 2009 Hi peter thanks for that seems to work a treat Nathan Quote
BoardwalkLD Posted December 11, 2009 Report Posted December 11, 2009 Hi Zero88 Gurus, I'm using PhantomZerOS to evaluate the possible purchase of a Leap Frog 96. My problems is this: Using Fixture Tools, a newly created custom fixture (Chauvet ColorDASH Par) with colors in the general tab/Special box set for Red - Positive, Green - Positive, and Blue - Positive, will display on the virtual console as Cyan, Yellow and Magenta. I've tried various experimental combinations of both RGB and CYM to get RGB to display properly and have had no luck. Only CYM will display on the virtual console's LCD above the jog wheels. As you can probably guess, I'm using Fixture Editor/Parameters/ General tab/Special box so that the fixture can be used with the color picker. What am I doing wrong with this? I'm including the fixture file I've been working with. ColorDASHv3RGB.ift Thanks much, Mark Quote
Kirkup_xp Posted December 13, 2009 Report Posted December 13, 2009 Hi Mark The desk defaults to CMY for all colour mixing fixtures. You can switch it to RGB by holding SETUP and COLOUR and selecting Colour Edit Mode - RGB. I hope this helps, Peter Quote Peter Kirkup
BoardwalkLD Posted December 15, 2009 Report Posted December 15, 2009 Hi Peter, I love a simple answer! It works great... RGB to my heart's content! Thanks very much. Mark Quote
NickTaylor Posted March 12, 2015 Report Posted March 12, 2015 I am using a combination of LED equipment. Having changed the Frog 2 to RGB, I note the wheels for levels move in the opposite direction to the other RGB kit. I cant see an obvious menu setting Quote
Jon Hole Posted March 12, 2015 Report Posted March 12, 2015 Hi Nick, Which version of software are you using? I think this might have been a bug in an old version of software. Regards Jon Quote Jon Hole linkedin.com/in/jonhole
Piero Posted April 16, 2019 Report Posted April 16, 2019 Hi, I’ve got the same problem on a Zero 88 solution, by default is using CMY and I want RGB, how to change it? Quote
Edward Z88 Posted April 16, 2019 Report Posted April 16, 2019 Hi Piero, Hold SETUP and tap COLOUR, and choose RGB. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
