Sorry, might be stupid question. :(
Is there any solution patch without into edit Fixtures mode?
i.e. assign dimmer onto fader instantly using key combination or something.
Because I have old desk (your company's) and they can do it.
I've read the manual and search logs at this forum, but I can't figure this yet.
thanx,
Hi Voice
You can use "add Fixtures" to patch dimmers too - select "Standard Fixtures" at the manufacfturer stage then "Dimmer", enter the DMX address and then press the fader you want to patch it to. Or use Edit Fixtures as you've already identified. The difference with Add Fixtures is that you're adding an entirely new fixture so there will be no cue information for that channel whereas Edit Fixtures will retain the cue information.
I hope this helps explain,
