pierotec Posted January 29, 2009 Report Posted January 29, 2009 Hello, I noticed that it would be very handy have displayed more of a cue / stack window in contemporary. What do you think? Pierotec Quote
Kirkup_xp Posted January 31, 2009 Report Posted January 31, 2009 That's a good idea, although we'd need to work out how not to complicate life for people who just want to select a stack and view the cues on that stack. What about the syntax VIEW STACK n ENTER would bring up a copy of the cue stack window which is locked to that stack? Quote Peter Kirkup
pierotec Posted January 31, 2009 Author Report Posted January 31, 2009 Hi, thanks for having considered my idea. Surely everything should remain as it is now. If we need this function can block and multiply the display of the stack that we wish have always on top, for example with VIEW and (SHIFT) SELECT buttons Thanks Piero Quote
Kirkup_xp Posted January 31, 2009 Report Posted January 31, 2009 Shift and the Select buttons for the stacks allows you to select multiple stacks at the same time, so I'd be hesitant to use that 'syntax' for something else. Would VIEW STACK n ENTER work? You can use VIEW CUE mm/nn ENTER to view a particular cue, so the syntax would follow logically. Quote Peter Kirkup
pierotec Posted February 1, 2009 Author Report Posted February 1, 2009 so it is certainly more correct Quote
