l8 Posted December 12, 2003 Report Posted December 12, 2003 I use a Fat Frog with a standard goose neck desk light fitted but this is'nt enough. When the light is fitted if the faders are at 0% the shadow hides the Channel number and the further down the desk you go the harder it is to see what is what. I know there is nothing that can be done for current owners like my self but would it be a good idea to make the Channel numbers and Submasters illuminated from behind in new builds? Quote Out of all the things I've lost it's my mind I miss the most!
Yves Posted December 14, 2003 Report Posted December 14, 2003 I had the same problem with the mambo. we've build it in a flight case with 2 extra lamps. It helpt a lot Quote
Kresten Bager Posted December 15, 2003 Report Posted December 15, 2003 Hi, I had the same problem. Just buy the long Littlite (they come in 6"/12"/18") as not all goosneck lamps work with the frogs. Kresten. Quote Kresten Bager Polyteknisk Scenelys www.scenelys.dk
