ryandell Posted December 20, 2008 Report Share Posted December 20, 2008 Hi All, Basically, I am in the process of planning possible chases for a band on the Fat Frog. So I have 4 minimacs, and the effect I want to create is as follows. I want to have a continuous chase i.e. an Ellipsis, for all the 4 minimacs. Then I want to flash one at a time, I have programmed many chases on the frog before but never thought of doing a chase like this. So just to recap, just one minimac flashes at a time then switches to another, so on. Has anybody achieved this/knows how to. Regards Ryan Dell Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 7, 2009 Report Share Posted January 7, 2009 Hi Ryan This should be easy - the effect parameters are just treated like any other parameter, so as long as you program them into each step of the chase (or set them in the first and then don't change them), then simply program the intensity chase in the steps as you'd expect. I hope this clears things up - please let us know how you get on, Regards, Quote Peter Kirkup Link to comment Share on other sites More sharing options...
ryandell Posted January 13, 2009 Author Report Share Posted January 13, 2009 Hi Peter, Thanks for the advice. So, Step 1 : All fixtures @ 0 Intensity, Position : Figure of Eight Step 2 : Fixture 1 : Full Position : Figure Of Eight and so on. Am I right in thinking that if I set the Fixtures to carry out a Figure of Eight pattern, then it will retain this throughout the programming of the chase ? Thanks, Ryan Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 13, 2009 Report Share Posted January 13, 2009 That is correct, Ryan. Quote Peter Kirkup Link to comment Share on other sites More sharing options...
