Hi guys
Have just been testing the new software release 4.4 - ever since PLASA I've been looking forward to test the Effects Window.
Why do all values follow each other:
An example:
Pan and Tilt can't have different values, even if only Pan is tagged, the Tilt values get the same values. This is true for every two or more parameters as far as I can see.
That makes no sense to me.
And it wouldn't hurt if the "tag"-toggle was bigger for touch screen use.
I personally liked the small text size in the MFK-display.
Could you add a text size changer in the setup?
When I use the arrows for browsing colour and effect palette windows, e.g. when I'm rearranging the palettes, the cursor stucks in the "Palette"/"Colour Picker"-buttons in the Color-palettes and stucks in the "Effects Window"-button. Unless I press the touch screen, I can't figure out how to get down to the palettes again. Do you have a hint, or is this not intended?
That's it for now.
I'll return I stumple upon anything.
Bo, Scenelys.dk
