Arts Tech Posted December 8, 2008 Report Posted December 8, 2008 I don't know if this is linked with my problem of desk crashes on chase, but anyway I set a scean with gen lighting through dimmers and DMX LED Par 56 on saving and running through the sceans the dmx side has not saved at all can anybody help (I have smart tag on I know this is going to be something sillybut eresopnce would be greatful Simon Arts Tech Salisbury High school Quote
Kirkup_xp Posted December 8, 2008 Report Posted December 8, 2008 Hi Simon Have you cleared your Program Window before playing back? Do you have a copy of the offending show file you can upload here for us to try here? Thanks, Quote Peter Kirkup
Arts Tech Posted December 9, 2008 Author Report Posted December 9, 2008 Hi I have attached a test show file this is the first 3 sceans. Just to confirm none of my DMX Par56's are not! been held in memory my smart tag is on and the window is cleared. many thanks Arts Tech TEST.isf Quote
Kirkup_xp Posted December 10, 2008 Report Posted December 10, 2008 Hi Arts Tech The fixtures you've provided on the desk have 5 channels - Intensity, Ch2, Ch3, Ch4, Ch5. My guess is that you're not programming the Intensity channel at a non-zero value. With Smart Tag enabled, any zero intensity fixtures are NOT stored into cues, to help "move on dark" work correctly. What are the 5 channels on the fixture? It would make sense to modify your fixture profile so that it is correctly labelled, as this will allow you to use things like the Colour Picker and Auto Palettes with your LED fittings. I hope this helps to explain what you're seeing, Regards, Quote Peter Kirkup
Arts Tech Posted December 12, 2008 Author Report Posted December 12, 2008 Many Many thanks for all you help on this matter every thing is running perfect. Merry Christmas to all at Zero88 and anybody reading this post Quote
