csylten Posted November 27, 2008 Report Posted November 27, 2008 Is it possible to make a "chase" or a rnd. chase on a ledbar, using the onboard effect generator? f.ex: put a sine or saw wave on RED1,RED2,RED3 and then set an offset so they go random? Quote
Kirkup_xp Posted December 8, 2008 Report Posted December 8, 2008 Hi there To achieve this i'd normally patch each cell of the fixture as a <Conventionals> RGB Dimmer. This means you can use the Fan function on the Offset of the effect to spread any effect across the cells of the fixture. I hope this helps, Peter Quote Peter Kirkup
