Is it possible to make a "chase" or a rnd. chase on a ledbar, using the onboard effect generator?
f.ex: put a sine or saw wave on RED1,RED2,RED3 and then set an offset so they go random?
  • 2 weeks later...
Hi there
To achieve this i'd normally patch each cell of the fixture as a <Conventionals> RGB Dimmer. This means you can use the Fan function on the Offset of the effect to spread any effect across the cells of the fixture.
I hope this helps,
Peter
