achamb Posted December 10, 2003 Report Posted December 10, 2003 Having just used the fat frog with the latest software release and checked it against the phantom frog I found a monitor message problem which you may be aware of. If editing a scene with fixtures in it and you change the brightness only of them. then when you click on edit to leave it asks if you want the C B P saving as well. On the frog desk LCD the toggles are set to "no" but on the screen they say default as "yes" Having saved it i found the default is no... but it is a bit confusing! Quote
ice Posted December 28, 2003 Report Posted December 28, 2003 If this is indeed the case, I thank you! In a previous show I did i wasn't able to correct my positions in certain scenes by editing, but I guess this would be the solution to my problem then. Didn't actually bother to take a look at the LCD, when you're used to the monitor that little thingy sucks Quote > 500 posts, time for a new T-shirt?
NZ Posted December 29, 2003 Report Posted December 29, 2003 Oops. Thank you for spotting that one and we will change it as soon as possible! Quote Graham
K-Nine Posted January 8, 2004 Report Posted January 8, 2004 Frog Reference No 5459 - C/B/P states on monitor screen do not match those on the main LCD when editing memories - Bug to be fixed in next update package. Having checked this on a desk here, it would appear that the data on the main LCD is correct and that on the monitor screen is wrong - so I can see how this could be confusing :? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
