You can do this using the EDIT button. Full details are in the user manual, but in brief:
- Press SUBMASTERS
- Select the one you want to edit using the submaster flash buttons
- Press EDIT
- Hold the channel flash button under the channel you want to change, then move it's fader to pick-up the level and adjust. Let go of the channel flash button when done. Repeat for other channels as necessary
- Press EDIT again to save the changes, and confirm the pop-up
