kalle Posted October 6, 2008 Report Posted October 6, 2008 Hi! I have a FAT FROG and i have a question. When i have made a chase with som mowing lights and then put it down to a submaster and want it to start when raising the sub fader it dosent start right away. It takes about 3 seconds before it starts. I have set the LTP fade time to 0. What do i do do wrong. Regards Kalle from Norway Quote
Paul Posted October 7, 2008 Report Posted October 7, 2008 If you want the chase to start as soon as the submaster is raised, then you need to also set the Fade Up and Fade Down times to 0. You get this by default if you use the 'Transfer No Time' button rather than the 'Transfer With Time' button, when transferring the chase memory to the submaster. Quote
kalle Posted October 8, 2008 Author Report Posted October 8, 2008 Hi! I have tried all these things you say but it doesen`t work?????????? Quote
Paul Posted October 8, 2008 Report Posted October 8, 2008 You need to set the fade times on the submaster, not on the chase memory, since the times programmed on the submaster override those on the chase memory. If you're still having trouble, please attach a copy of your showfile so that we can take a look at it. Quote
