brianstorm Posted August 19, 2008 Report Posted August 19, 2008 Hi, am i right in thinking that when I set a gobo (including rotation position) with an absolute value that the gobo should return to the same position? Its programmed onto a submaster if that makes any difference. I am finding that my gobos do not return to the exact orientation which is not really suitable for a text gobo. Is there anything I should look at? The fixtures are robe moving heads (possibly clubscans?) Thanks Brian Quote
Kirkup_xp Posted August 19, 2008 Report Posted August 19, 2008 Hi Brian Most moving heads have two sets of Gobo values you can dial in - the "Indexing" value or the "Rotating" value. You need to make sure you're using the Indexing version if you want them to return to the exact same orientation. It is, of course, possible that the fixture itself has a fault or simply isn't capable of this function. Hope this helps, Peter Quote Peter Kirkup
brianstorm Posted August 19, 2008 Author Report Posted August 19, 2008 Thanks for the reply - should I be looking on the desk or the fixtures for the 2 different values (rotating / index)? Quote
Kirkup_xp Posted August 20, 2008 Report Posted August 20, 2008 Under the Gobo wheel, the first time you see the gobos (say DMX values 0-127) they will be indexing, and the second time you see them (say 128-255) they will be rotating. Depends on the exact fixture for the details - have a read of the fixture user manual for more information. Hope his helps, Peter Quote Peter Kirkup
Rigorr Posted September 2, 2008 Report Posted September 2, 2008 dont forget that with the indexing function on rotating gobo's that they often also use the gobo rotation channel to set the index. Robe's Scan range - Click me to get a list of scan's, and their dmx attribute list Quote
