brianstorm Report post Posted August 12, 2008 Hi, I'm a new user and I'm wondering if anyone can explain the different uses of scenes vs memories, vs programming straight onto submasters? The manual mentions scenes and memories, but as a novice i'm not sure what they for. And any useful shortcuts / tips would be great too! thnaks Brian Quote Share this post Link to post Share on other sites
Paul Report post Posted August 13, 2008 Memories are used when you're running the same show, night after night, and you want to pre-program the lot and just run through it using the Go button. A memory can be a static look (scene), or a chase (useful for effects). Submasters are used when you're not sure what might be coming up next in a live show, and you want lots of different looks available so you can mix & match (busk) live. For some general lighting background and terminology explanation, have a look at the Blue Room Wiki, particularly Lighting Desk Features. Quote Share this post Link to post Share on other sites
brianstorm Report post Posted August 15, 2008 Thank you! Quote Share this post Link to post Share on other sites
Isaac Report post Posted August 6, 2009 Hi! I'm from Switzerland so I don't speak your language very well. I sometimes use a BullFrog with the theatrical company of my high school (I'm 16). Well, 'cause the teather isn't public I can't learn to use the BullFrog better and learn more functionalities of it (to do a better "lightning set" next year) directly on the desk. So, I downloaded the manual and the Phantom Frog program, but there are still some things I don't understand reading the manual and remembering what the director of the teather told me in May when he explained to me the most basic features of the lightning desk. Especially I can't understand what functions are related on these terms: - what's the LTP fade time? - what means "dwell" on the Frog? - idem for "trigger"... - what is a chase and which function control the "Drive", "Direction" and "Attack" buttons? Well, reading the post upper I understand that if I have to program a set of lights (a scene) with fading times and names, I can put it into a memory and, using the Playback X function, put it on (button GO; Pause and Override, or Step if something changes in the order of playing). Otherwise, if I want a complete manual control I can use the Submasters. It's correct to say that it isn't useful to use a CHASE memory if the theater hasn't DMX lights? I think that 'cause the fixtures control (moving lights and others DMX llights) aren't enabled in the theater where i usually work. Excuse me for the very very very bad English and big greetings. Isaac Quote Share this post Link to post Share on other sites
