John_Schlick Posted December 9, 2003 Report Posted December 9, 2003 HUH? Am I missing something. I can't edit a submaster? Thats just silly. I appear to need to record a memory, and then dump that to the submaster. WHY? Why not just allow me to edit a submaster the same way that I edit a memory? John. Quote
K-Nine Posted December 9, 2003 Report Posted December 9, 2003 You can only 'edit' a submaster which is already programmed either with channel data or a transferred memory. If by 'edit' you actually mean Program an unprogrammed submaster with channel data, you display the submaster screen, select your submaster, set up your generic channels and/or fixtures as required and press PROGRAM. See Frog Series Operating Manual - Chapter 5 for full details. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
