Okay,
We just want it to WORK now,
Me and my group of amatures trying to set up the lights for this ****ed concert,
It was working friday, but someone sabotaged the equipment, now we need to manually reset everything.
Okay, we have 4 dimmer racks
Each with 6 channels
Each with two plug sockets
Each dimmer is daisy chained to the next.
Now,
Atm
Rack one has the DMX address of = 100
Rack two = 200
Rack three = 300
Rack four = 400
Now, Rack one, Channel 1 has 2 lights plugged in, however on our frog, when we raise channel 1, 4 lights come on, we suspect its because of a clash in DMX address'
Any tips Guys
I Love You if you can fix this, honestly.
The easiest way to get everything going again is to go back to the default DMX patch on the Frog, which will give you 48 channels patched 1:1. Go to SUPER USER -> DESK SETUP -> PATCH FUNCTIONS -> SET DEFAULT PATCH to do this.
Then set your Betapack2's to have the following DMX Addresses:
Pack 1 (channels 1-6): DMX Address 1
Pack 2 (channels 7-12): DMX Address 7
Pack 3 (channels 13-18): DMX Address 13
Pack 4 (channels 19-24): DMX Address 19
You should then have control of all your channels again.
