Barn01 Posted July 7, 2008 Report Posted July 7, 2008 Hi, I have a quick question I am hoping someone can help with me - I warn you in advance I am not very savvy in all things lighting/lighting terminology so please excuse my Our Sirius 24 seems to be in working order except for a number of channels which we suddenly appear to have no control over from the board. So long as the lamp has power, it is on at 100% and we have no control over it on the channel. This is happening on 3 or 4 channels. If you have any troubleshooting tips you can recommend to diagnose/solve the problem? Is there something on the board itself that could be overriding the channel. Or are we looking at a failure on the board itself. Thanks in advance for any assistance you can provide. Gareth Quote
Robin D Posted July 9, 2008 Report Posted July 9, 2008 I'm assuming that by 'no control' even the grand master is not controlling it? If so, its unlikely to be the desk so the first thing is to find out of you are running analogue or DMX? Also are the lamps DMX or driven from a dimmer pack? If analogue the first thing to check out is the control cables and connectors making certain you have no shorts between circuits or screen of the connectors. If the devices are attached to a dimmer, that could also be the cause of the problem. However, if grand master does affect the channels in question, then it may be dodgy faders. If you contact Keith Rogers at Zero88 he will be able to advise on spares. If you can't resolve it, please post back with more detail of the packs, lamps and answers to the above so that we can help tie the problem down. Robin Quote
