Hi Gavin
The remote software is due for launch in a couple of months, and is currently undergoing testing. The software will only function on a Pocket PC device and not on a Laptop - for a Laptop you want Phantom which is the offline editor. I hope this helps,
Hi Gavin
You can only edit shows offline - there is no link between Phantom and the consoles themselves. We have talked about adding such a link, but that won't be in the next version.
Peter
  • 3 months later...
Gavin H recommended laptop feature which I agree it would be really useful thing. if zero88 engineers will make this feature I recommend that they take a look how yamaha m7cl digital mixing console have this solved. it is the whole mixing desk on computer. my friend has that console and he mixes thing directly from computer. i have tried it too and it is really great.
regards
  • 8 months later...
Is there a way to use more than one screen to see lot of informations? On a leapfrog if I use the palettes i have my touch screen completely in use.
So i can’t see the memories, subs (ok they are on the sub-displays) but also very important – the output-window!
If i can use a PC / laptop to view some of these informations it would be very helpful.
Carl
Carl Ehrhardt
Technical Director
Kellerbühne St.Gallen
CH-9000 St.Gallen
Switzerland
www.kellerbuehne.ch
Hi Carl
The way I do this on the Leap Frog is to open the windows I want at the time by pressing the Memories, Outputs, etc buttons when I want to see that information. The Frog 2 has 2 monitor displays, as does ORB.
We have discussed adding the ability to view displays on a PC application at a later date. Your comments have been added to the discussion.
I hope this helps,
Peter
