bertnut Posted June 24, 2008 Report Posted June 24, 2008 Hi If I try and overwrite a submaster I get the promt to cancel or overwrite, so I select overwrite but the changes never save. Anyone else having the same issues or am I missing something?? Thanks S Quote
Paul Posted June 25, 2008 Report Posted June 25, 2008 When you use the submaster flash button to select a submaster on the Jester, it outputs that submaster. So you need to make sure you pick the submaster you want to overwrite before you start making changes to the channel levels. Quote
BenKu Posted February 18, 2009 Report Posted February 18, 2009 Hello, I work with Jester 24/48. If I want to change a saved Submaster, the used Channel-LEDs flashs and I had to move the Faders up and down, so that the LEDS switch off. Then, I can create a new lightsetting and save (Overwrite) the old submaster. I don´t want to move the old Faders, i only want to overwrite an old, never again used submaster. How can I do this? Another way could be, to delete a single submaster. Is there an easy way? I don´t want to use the function in Superuser-mode "delete alle Submasters". Thanks for help. Ben Quote
Paul Posted February 19, 2009 Report Posted February 19, 2009 You can delete a single submaster in Program Mode by first selecting it with it's flash button, then holding down the CLEAR button for a couple of seconds. Quote
