s d jefferson Posted June 23, 2008 Report Share Posted June 23, 2008 I have a Bullfrog running 10.1. On Friday, the dimmer wheel refused to dim any of our moving lights, it just made them start flashing. However the wheel works perfectly on the other functions such as pan/tilt colours and gobos. This only became an issue on Friday. We were able to work around it as this was not a show, but what is happening? I have taken the board apart and put it back together and there are no loose parts or cables and everything else work fine. Can anyone help? Simon. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted June 23, 2008 Report Share Posted June 23, 2008 Hi Simon The fixtures are treated HTP so if they are programmed at 100% on the memories or a submaster is up at 100%, you won't be able to dim them down. Try bringing the Playback X master down and all the Submasters and see if that helps. What fixtures are you using? Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
s d jefferson Posted June 24, 2008 Author Report Share Posted June 24, 2008 Hi Peter I am using Robe 575 AT ColorWashes and Robe 575EAT ColorSpots running in Mode 1 and the problem has only just arisen after using them for 4 years. However I will try your recommendation and get back to you soon Thank you for your advice Simon Quote Link to comment Share on other sites More sharing options...
