Carwyn Posted May 21, 2008 Report Posted May 21, 2008 hi the copy button does not seem to be copying the ques you request properly asin it soesnt capture all the channels Thankyou Carwyn Quote
Kirkup_xp Posted May 21, 2008 Report Posted May 21, 2008 Hi Carwyn Copy will copy the *programming* in the cue, not the state of the cue itself. Because the desk is tracking, this means that copying may not copy the whole state. To record the whole state into another memory or submaster, play it back and record it into the new location with Smart Tag enabled. Hope this helps, Peter Quote Peter Kirkup
Carwyn Posted May 24, 2008 Author Report Posted May 24, 2008 Kirkup_xp said: Hi CarwynCopy will copy the *programming* in the cue, not the state of the cue itself. Because the desk is tracking, this means that copying may not copy the whole state. To record the whole state into another memory or submaster, play it back and record it into the new location with Smart Tag enabled.Hope this helps,Peterthanks peter Quote
