Thomas Haaser Posted May 20, 2008 Report Share Posted May 20, 2008 Please help me. My Way is not good, or? Setup: SETUP->DESK SETUP->BEHAVIOUR->PRESET MIX MODE = HTP The Way: 1. Preset 1 of 100% 2. SPEZIAL (Side 1) FLASH MODE SELECT/OFF 3. select the channel for a chase with the flashbuttontaste (or a Memory) 4. value with the Presetfader for example Steps to recalibrate to recalibrate to recalibrate to recalibrate Programmer Kanal 1 2 3 4 1 2 3 4 1 Step 1 100 100 0 0 100 0 0 2 RECORD SUBMASTER 1-1 100 0 0 3 Step 2 100 0 100 0 0 100 0 4 RECORD SUBMASTER 1-1 0 100 0 5 Turn into Chase 6 Step 3 100 0 0 100 0 0 100 7 RECORD SUBMASTER 1-1 0 0 100 8 2 x CLEAR now start Submaster 1 what is Submaster 1 what hope saved on submaster 1 (not CUE ONLY not SMART TAG)" Channel 1 2 3 4 1 2 3 4 Step 1 100 100 100 Step 2 100 0 100 0 100 Step 3 100 0 100 0 100 record result to abide with not CUE ONLY not SMART TAG with CUE ONLY not SMART TAG with CUE ONLY with SMART TAG not CUE ONLY with SMART TAG What is the correct way for the chase or memory in the HTP-mode?? Zero88_test_140508.isf Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted May 22, 2008 Report Share Posted May 22, 2008 Hi Thomas To create the chase that you are trying to achieve, you need to do one of two things: 1. Use LTP mode. In LTP mode, moving a fader will tag it in the programmer, so if you don't move Preset 1 (or move it and then hold down CLEAR and move it again to untag it) then your chase will only contain channels 2,3 and 4. To do this you will need Smart Tags disabled, as when they are enabled they desk will also store channel 1 (because that channel is 'different' to the value it was already at). 2. Use HTP mode and turn off Channel 1. In this situation the desk will store channels 2,3,4 but not 1 because it is off. In HTP mode the desk will store ALL preset channels when you press RECORD and they will be mixed HTP. It is important to note that in HTP mode, the fader levels are not shown in the Program Window because they will not be affected by the CLEAR button. In LTP mode they appear in the program window because they will be affected by the CLEAR button. I hope this helps to clear things up a bit. Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
