VII SOG Posted April 30, 2008 Report Posted April 30, 2008 hey fellow froggers, recently started using the fat frog desk, this forum has been invaluable in getting my head round the desk. thank you all!!!! ive now started to try and use the frogbox to replay shows but it seems every time i call a chase memory the mac's go to 0 (pan tilt etc) and all the generics also got to 0, scene memories all seem fine. I have updated both the desk and box to 10.9, didnt use the box before this, is there anything i need to do to the box to get this working? (ie set up fixtures?) in the frog box manual (issue 4c) it seems you can run chase memories, tho I cant get it working!? cheers, sog Quote
VII SOG Posted May 1, 2008 Author Report Posted May 1, 2008 Not sure if this is the right place to ask, How Do I get memories programed on a fat frog (v10.9) to work on a Frog Box (v10.9)? the generics work fine on their own as scenes but when i run a chase everything seems to recieve dmx 0 (all generics go off and mac 250's point at ceiling with no light) I'm sure it's me overlooking something simple but have read both manuals and the release notes to no avail. thanks in advance. sog. Quote
Paul Posted May 6, 2008 Report Posted May 6, 2008 This is a bug introduced as an unfortunate consequence of implementing FR 5378 and FR 5422 in version 10.8. Because the Frog Box does not have master faders, it is wrongly stopping chases, which is behaviour that was intended for the desks only. Frog Reference 5592 - Chases, movement effects and FROG effects do not replay correctly on Frog Box. We will be fixing this, however with other work that's going on at the moment, I can't give you a timescale right now I'm afraid. Quote
VII SOG Posted May 7, 2008 Author Report Posted May 7, 2008 thanks Paul, I thought I was doing something wrong, I guess for the time being I need to downgrade the box and desk to a version lower than 10.8? first I'll try some basic scenes with the MACs using the built in movement effects. Thanks again for your help. sog. Quote
Paul Posted May 8, 2008 Report Posted May 8, 2008 The only thing to watch with older versions on the Frog Box, is that you don't program any submasters in your showfile, otherwise they may be output at spurious levels. This issue (Frog Reference 5573) was fixed in version 10.9. Quote
