Yves Posted December 1, 2003 Report Share Posted December 1, 2003 how do you change the moving speed live when the program is running? I know you can change the time of a step, but then moves the moving head at the same speed. :? greetz yves Quote Link to comment Share on other sites More sharing options...
K-Nine Posted December 1, 2003 Report Share Posted December 1, 2003 If you are referring to being able to adjust the speed of a chase live, this is something we are looking at including in the next Frog software update. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
l8 Posted December 11, 2003 Report Share Posted December 11, 2003 Am I right in saying if the chase is driven by sound/music say on Bass then this wouldn't matter. Quote Out of all the things I've lost it's my mind I miss the most! Link to comment Share on other sites More sharing options...
KWR88 Posted December 11, 2003 Report Share Posted December 11, 2003 You are correct if you are on bass drive the speed control has no effect Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Yves Posted December 11, 2003 Author Report Share Posted December 11, 2003 how do you put the chase on bass drive? didn't know that you could do that. :oops: Quote Link to comment Share on other sites More sharing options...
Haytech Posted December 12, 2003 Report Share Posted December 12, 2003 how do you change the moving speed live when the program is running? I know you can change the time of a step, but then moves the moving head at the same speed. What kind of moving head do you use ? - most of them have a movement speed option. push thru the other wheel groups of position search for Mspeed. Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone Link to comment Share on other sites More sharing options...
Laubfrosch Posted December 12, 2003 Report Share Posted December 12, 2003 Hi Yves, to set an existing chase to Bass trigger, recall the depending Memory to the Frog Mais Display as Next. Then push the edit button. Now you´re able to set the chase to bass with the lowest button in the chase section of the Frog. Push this button several times till the Bass LED is lit. Cheers Sven P.S.: You don´t need to run "red faced"!!! :wink: Quote Sven Paulsen Klangfarbe Vienna Link to comment Share on other sites More sharing options...
K-Nine Posted December 12, 2003 Report Share Posted December 12, 2003 how do you put the chase on bass drive? didn't know that you could do that. :oops: For further info on Chase memories see the operating manual :wink: Chase Modifiers - Page 4-2 Programming a Chase - Page 4-8 Modifying Chases - Pages 4-10 and 4-11 Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Yves Posted December 12, 2003 Author Report Share Posted December 12, 2003 I'll try it. PS. I'm using movtec sl250, martin mac 500, mac 600 & martin 218 Quote Link to comment Share on other sites More sharing options...
K-Nine Posted December 12, 2003 Report Share Posted December 12, 2003 I'll try it. PS. I'm using movtec sl250, martin mac 500, mac 600 & martin 218 The movitec sl250, MAC 500 and MAC 600 have movement speed parameters which effect how the actual head moves. This parameter will probably be called "P/T Spd" or "Mov Spd" and be in the first position wheel group after Pan and Tilt. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Yves Posted December 12, 2003 Author Report Share Posted December 12, 2003 I'll try it out. thx Quote Link to comment Share on other sites More sharing options...
