ymaod Posted April 10, 2008 Report Posted April 10, 2008 Hi, I would like to make scenes(and other movements) where moving heads light several parts on stage. How can I program a movement or a scene and put them under a pallette so that I still can use the colour,beamshape etc pallette to change the fixture's colour etc and put the moving heads in the programmed scene with just one push of a button(like in the pallettes). This really comes in handy on concerts and parties when just doing the ambilights. I already tried programming scenes for fixtures under a submaster but when I raise the fader or push the flashbutton under the submaster nothing changes. Also: is it possible to program chases with generic lights and play them while keeping the pallettes active? (practicly the same as the moving heads) Best regards, Yannick Quote
Bullitt No9 Posted April 22, 2008 Report Posted April 22, 2008 you have to set your console at [sUPER USER]->[DESK SETUP]->[PROGRAM MODE] Mode: Partial Position:All then You can program the movments transparently to the submaster. (look out for the Lamp on Brightness,Color and Beamshape Button it's off ) otherwise hold it 2sec to turn them off, same with the moving heads(fixtures) that wouldn't be programmed Quote
