daoops Posted November 27, 2003 Report Posted November 27, 2003 - I have a sort-of disco show after the main-show, and they requires some disco effects. But since I don't wan't to sit and control the desk (Due to the cost of money), I wan't the moving heads & scanners to do a random show. Like after audio-signal or just random. How can I get my Moving heads and scanners to get an random output from my FatFrog. - How to I change the speed of the scanners in a "live-show" Quote
K-Nine Posted November 27, 2003 Report Posted November 27, 2003 If you want the scanners and moving heads to do a random show, the best way is to program one or more memories, as required, and use the FROG function to output different colours, gobos position etc. There are a number of FROG parameters which determine if the output values snap or fade, speed, drive etc. See the Frog Series Operating Manual Pages 7-4 and 7-5 for details. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
pro_tech Posted January 6, 2004 Report Posted January 6, 2004 Chill. Do this in order!! 1) Select your fixtures 2) Hit 'Position' button 3) F.R.O.G button 4) Hit 'Colour' button 5) F.R.O.G button 6) Hit 'Beamshape' button 7) Once again....F.R.O.G button. Simple Let it run all night doing random things Quote
Pipo Posted January 8, 2004 Report Posted January 8, 2004 or you can just create some memories and add a jump to it, so that when memory 1 is finished it goes to memory 2,.... Quote Den Pipo Pro Light Design
