Kirkup_xp Posted February 22, 2008 Report Share Posted February 22, 2008 Hi there Unfortunately it is not possible to do this on the Bull frog. You can create a fixture profile which controls a particular DMX address, however fixtures are treated Latest Takes Precidence so moving a wheel or playing a memory that contains that fixture will adjust it to whatever level has been requested. What is it that you're trying to achieve - there may be a simpler way using the memories on the chilli dimmer, if you don't need remote control from the desk. Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
A Man With A Lighting Plan Posted February 22, 2008 Report Share Posted February 22, 2008 Hi It's not necessary, per se, but for the future it will be very helpful. I am trying to use my BF to control certain things that we otherwise have to plug into 13A sockets, such as our mirror balls, UV cannons, and other things that have to take On 240V or Off. Thanks Adam. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted February 23, 2008 Report Share Posted February 23, 2008 You can purchase a relay rack, such as our Switch 6, which does exactly this and responds to a normal 'dimmer' channel. This will give you true 230v supply, rather than going through a dimmer which still has a chopped waveform and may cause you problems with certain types of load. Quote Peter Kirkup Link to comment Share on other sites More sharing options...
A Man With A Lighting Plan Posted February 25, 2008 Report Share Posted February 25, 2008 What happens to the waveform? Do you have any images I could compare so I dont have to dig out my 'scope? Quote Link to comment Share on other sites More sharing options...
