NickTaylor Posted March 23, 2008 Report Posted March 23, 2008 I have a couple of these to try out. A lot more light than the original LED pars. I have had a surf but cant find a fixture available. I will download the up to date fixture list as well DMX protocol Ch 1 Red Ch 2 Green Ch3 Blue Ch 4 Dimmer Ch 5 Flash Many thanks Nick Quote
NickTaylor Posted January 2, 2009 Author Report Posted January 2, 2009 Not one answer since last March. Okay I had a look at the fixture listed. It seems to start with channel one as Brightness. As I previously posted mine start with colours and make 4 the brightness. Has anyone actually tweeked the fixture gile? I cant seem to use the editor right Thanks Nick Quote
chw Posted January 3, 2009 Report Posted January 3, 2009 Not one answer since last March. Okay I had a look at the fixture listed. It seems to start with channel one as Brightness. As I previously posted mine start with colours and make 4 the brightness. Has anyone actually tweeked the fixture gile? I cant seem to use the editor right Thanks Nick The Fixture you are looking for is Eurolite LED Par 64, included in the Fixture Lib. version 20 and as far as I know in some of the Libs before... You have to differ between "Parameter" and DMX "Channel". So the Intensity can be Parameter #1 but the channel can be 4,5 or whatever the fixtures manufacturer defined. Kind regards Christian PS: Take a look at the Fixture Type Editor - to create such a small Fixture like a LED RGB Parcan with 5 Channels you need a couple of minutes - not more. Quote
NickTaylor Posted January 17, 2009 Author Report Posted January 17, 2009 Thanks for that reply. I have got the Par up and running . However I have revisited my older Showtec Pars and they have a Macro channel, 4 which acts like a scroller control. Actually I just reinstalled them on my Frog and cant remember where the Macro actually appears as a wheel. Any ideas to both questions? Quote
chw Posted January 17, 2009 Report Posted January 17, 2009 Thanks for that reply. I have got the Par up and running . However I have revisited my older Showtec Pars and they have a Macro channel, 4 which acts like a scroller control. Actually I just reinstalled them on my Frog and cant remember where the Macro actually appears as a wheel. Any ideas to both questions? Yes. Load the Fixture file (or a copy from the original Library) into the Fixture Editor and take a look at "Parameters". Maybe there is no "macro channel" in the List yet or its named different. To assign a wheel to that channel, create a new Parameter and choose channel 4 and the Section, like Beamshape or Color. After that go to "3 Wheel Group" and select the Wheel you want to assign to that Parameter. (double click the Color, Beamshape or Position Tag) Safe the file and transfer it to the desk. Quote
NickTaylor Posted February 15, 2009 Author Report Posted February 15, 2009 Thanks for the tip. I will try that. I know have a different problem. I have tried to make up a floppy disk of the two LED pars that can be inserted on another Frog. However what ever I do I get "no fixtures on disk", even though the formatting was carried out on the desk, and I can see the fixtures on the floppy on my PC. Any ideas? Quote
Paul Posted February 15, 2009 Report Posted February 15, 2009 Make sure the filenames are shorter than 18 characters, end in .ift, and don't include any spaces or other special characters. Sticking to DOS 8.3 filenames will give the most reliable results. Files must go in the root directory on the floppy disk, not in any subdirectories. Quote
NickTaylor Posted March 1, 2009 Author Report Posted March 1, 2009 Yes. Load the Fixture file (or a copy from the original Library) into the Fixture Editor and take a look at "Parameters". Maybe there is no "macro channel" in the List yet or its named different. To assign a wheel to that channel, create a new Parameter and choose channel 4 and the Section, like Beamshape or Color. After that go to "3 Wheel Group" and select the Wheel you want to assign to that Parameter. (double click the Color, Beamshape or Position Tag) Safe the file and transfer it to the desk. Okay. I have the time to look at this further. trying to get 6 showtecs and 8 Eurolights set up before the move in. I must be particularly stupid, but I use the fixture manager to find the fixture,then I open editor and try and open the fixture but it cannot find it.What is going on! All I want to do is setup a colour mag as suggested! Quote
