rfisher Posted March 13, 2008 Report Posted March 13, 2008 I couldn't find any other topics on Light Factory, so I'm not convinced I'm in the right forum. If I am though, here is my question; I've just bought the Light Factory software, so I'm not a whizz at it yet, and I could be doing something stupid. I've patched in my old Martin Roboscan 518's, and everything works fine (gobo, colour etc) except movement. Each 'degree' moves the mirror from one extreme of its movement range to the other. But only pan (or tilt, I can't remember which) with barely any movement in the other plane. As a control test, I've patched in some nasty Martin 'disco-tat' scans that I own (SCX 500's I think) and they behave perfectly. The 518's have also worked fine on our Strand 520, so I think the fixtures themselves are fine. Any help with this would be much appreciated. Robin
Robin D Posted March 14, 2008 Report Posted March 14, 2008 Hi Robin. I think you need Light Factory. Best wishes ........ Robin
lxkev Posted March 14, 2008 Report Posted March 14, 2008 It dead easy to fix I had the same prob. on the fixture file you need to swap the data on the pan and tilt as it wrong. i.e. Low PAn and High pan are the wrong way ......low til and high tilt are also the wrong way You need to change the channel data... I hope that makes sence I need a new job
rfisher Posted March 14, 2008 Author Report Posted March 14, 2008 Thank you both very much. Just the answers I wanted. Cheers, very very much! Robin
Kirkup_xp Posted September 15, 2008 Report Posted September 15, 2008 We've now added a link to the LightFactory Forum to the main forum homepage - please address all LightFactory questions there Peter Kirkup
