Carwyn Posted March 12, 2008 Report Posted March 12, 2008 It might be worth on the mfk when in the command line mode to put a rem dim button Thanks Carwyn Quote
K-Nine Posted March 13, 2008 Report Posted March 13, 2008 Sounds like a good idea. The problem at the moment is that the command line MFKs (Special Page 2) are all assigned. However, if one can be identified that is not required in command line mode it could be replaced by a REM DIM key perhaps Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Carl Ehrhardt Posted March 14, 2008 Report Posted March 14, 2008 It might be worth on the mfk when in the command line mode to put a rem dim button Thanks Carwyn Oh yes - would be very usefull! just had the same wish :-) Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
Carwyn Posted March 16, 2008 Author Report Posted March 16, 2008 I cant see any reason why we need a . (dot) button in that window Quote
Kirkup_xp Posted March 17, 2008 Report Posted March 17, 2008 I think we should use SHIFT+FULL as we do on the Frog 2. Quote Peter Kirkup
Carl Ehrhardt Posted March 17, 2008 Report Posted March 17, 2008 I think we should use SHIFT+FULL as we do on the Frog 2. Yes that sounds good! Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
