Carwyn Posted February 22, 2008 Report Posted February 22, 2008 Is it possible to turn one of my dimmers to a non dim through the desk to control my optical starcloth Quote
Kirkup_xp Posted February 23, 2008 Report Posted February 23, 2008 Yep - patch a "relay" fixture (found under Standard Fixtures/1 Channel or 6 Channel), which will give you a beamshape attribute to control the relay. You can then simply set the default value to 100% and the channel will stay on when the desk is booted, until you tell it to change. Peter Quote Peter Kirkup
