Carl Ehrhardt Posted February 14, 2008 Report Share Posted February 14, 2008 I have a question about the ColorCommander. As i think it would be usefull to have a "ColorComander + Dimmer" Fixture. So we can work with move on dark. Now i only have CMY and the angle that can be programmed. Is there an other way to get it work like that? Greetings from cold Switzerland! Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
K-Nine Posted February 15, 2008 Report Share Posted February 15, 2008 You should be able to use the fixture editor to take the original fixture profile and add a separate dimmer subfixture. When patching the new fixture the dimmer and the colorcommander would have their own DMX start addresses. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Kirkup_xp Posted February 18, 2008 Report Share Posted February 18, 2008 Hi Carl I've created the fixture for you... attached. Hope this helps Peter col_command_dim.ift Quote Peter Kirkup Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted February 18, 2008 Author Report Share Posted February 18, 2008 Hi Carl I've created the fixture for you... attached. Hope this helps Peter Thanks - have done nearly the same setup. And it's exactly what I was looking for! Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
