Hi,
It would be nice to have the remaining fade time displayed , it is more accurate than a progress bar and would be very appreciated by theaters.
you could use for example the format: up XX/YY down XX/YY
where XX is remaining time and YY the programmed time. it would just take a space of 1 line above the bar.
David
Hi,
David
Yes that would be very helpful - so we have also a way without 2 progress bar as on other topic shown ;-)
Carl Ehrhardt
Technical Director
Kellerbühne St.Gallen
CH-9000 St.Gallen
Switzerland
www.kellerbuehne.ch
Does this mean you are only interested in the intensity fade times ?
There are also Colour, beamshape and position fade times applicable to the memory if the corresponding fixture parameters are programmed :P
Bran Media | Myspace
Well for me the most important fade time is the brightness - all others are nice to have but not necessary. For the Color, Beamshape and Position it could be something like on the Memory-Screen. That setting which is selected on the buttons (Color, Position, Beamshape) is show the fade time.
There is also the move on dark that could be indicated if and when it's changing any settings.
But for me the first would be first of all enough.
Carl Ehrhardt
Technical Director
CH-9000 St.Gallen
Switzerland
www.kellerbuehne.ch
