Hey Guys,
I am having major problems updating memories that were recorded with Smart Tag on. If i load a memory to be updated it will update that memory but throw random things in the memory after it or just drop info completely. If i am just sitting in the cue and do not load it most of the time it just ignores what i have tried to update it with. This is becoming a huge problem as i can not update properly. There are even times when i have recorded 4 memories and have updated memory 2 and thing would change in this memory than memory 3 would be OK but then memory 4 would be way out of wack.
I really can even explain it. I can give you very basic explanations if you need them but this is really staring to suck!!!!!!!
Hi Tara
There are a number of bugs we've found with Cue Only updates in version 2.15 which are in the process of being fixed. We'll have a public beta test version out shortly which should fix the majority of them, but please let us know of any examples and we'll get onto them straight away.
Peter
