Alan Posted February 1, 2008 Report Posted February 1, 2008 Hi A couple of weeks ago I was running a show that I had rushed to get set up and I realised that I had 'Programed' into my memory stack rather too much Haze on one of the scenes (normaly operate this live as required) but I didn't know how to 'turn it off'. I presume this can be done could somebody please tell me how? Cheers Alan Quote
Paul Posted February 2, 2008 Report Posted February 2, 2008 If you are using one of the preset faders to control the haze, then you can use the Grab Mode (Frog Reference 5574) introduced from version 10.8 to take control of the channel and lower the level. See the release notes (DOWNLOAD HERE) for a full description of the operation. Quote
pollywog Posted February 8, 2008 Report Posted February 8, 2008 Easier, and also fixed for the next show: switch to Memory View [Memory Button] use up / down Buttons: Yellow Line is over Green Line press [Edit Button] press the Fog Generic Flash button enter new Value via Keyboard press [Edit Button] again That`s it. Or am I wrong ? Quote
iamchristuffin Posted February 8, 2008 Report Posted February 8, 2008 Whenever I've tried doing that, the state currently 'on' has always blacked-out - not something you want during a show! Chris Quote
Alan Posted February 8, 2008 Author Report Posted February 8, 2008 Hi I knew you could go into edit mode (which I have done after a show) to correct any problems, but I did fear the blackout 'scenario' if I tried it whilst the show was running! Quote
Morn Posted February 10, 2008 Report Posted February 10, 2008 Press "Preview" Button, before pressing "Edit" button...you will get in "Blind Edit" mode, which means that current outputs are not affected by the editing process. :-) Quote So, if you don't start drinking...I'm gonna leave!!!
