I have just purchased a Leap Frog 48 and having read through all of the documentation I can find no information appertaining to the sound to light input on the back of the console. Where can I find information regarding this?
The Sound to Light input is used when a chase has the Drive modifier set to Bass. The bass beat of the incoming sound signal is used to trigger each step of the chase.
Wow what a quick response - impressed!Your answer makes perfect sense, thanks.Is there any spec regarding the incoming sound signal level? I'm guessing any normal audio signal will work but could this just be a pre-amp signal from a mixer or does it have to be a post amp signal i.e. the signal going to the speakers. Can this input be "overdriven" or is it protected in some way?
